I'm not sure if its standard or not. He says its about 4hp.
I might get a different filter, or at least make sure the outer wear is on it.
The bloke has had it about 3 years, so said there is loads of spares and stuff with it, so will have to go and have a look.
I was contemplating buying a new FG, but i'm a sucker for modifying, so buying this with all the alloy bits already on and tunes pipe etc will hopefully save me a fortune.
How would i go about putting a MT shell onto this Beetle? I think i prefer the monster truck look.
Cheers
Matt
i think front are same but rears are different all you do is take rear mount off and use the wing mount for the truck body i think?
Thanks for the info Al. I'll just wait to get the beetle, then get a truck body and suss it out.
Hi Bigtoyz, I should be goin looking at the beetle tomorrow. The bloke who owns it has been on holiday.
I picked up the monster beetle yesterday
A couple of the gears are nearly ready to be replaced, but new steel ones were included in the sale.
It's running all steel gears, except the spur gear which is plastic. He said he did this to protect the gears and diff etc. Is this the norm?
It started first pull, and ran well.
It runs with 2 battery packs on board. Is this normal, or a modification for longer run times?
The car needs a bit of tidying up, but looks good otherwise.
Cheers
Matt
easy mate, what you paid for it ? love it when a good deal goes through
