Sprint 77
- Gladewater Texas USA
I am going to be running Two HS-5955TG Hitec servos for my steering, One for throttle , back brake and one on third channel for mixing front brakes. My question is do I need to a harness that runs the voltage direct from battery and the signal from the reciever like the large scale plane guys do. These are high drain digital servos. I also plan on running a Li-Po 7.4 volt battery with a voltage regulator, What mah will be needed 2200?
Servo Spec @6.0 volts 333 oz.in torque .15 sec/60 deg.
