Joek72
- Reaction score
- 30
Hey guys so I got a obr 30fm and I was going to use the stock motor to complete it. The stock motor is the dynamite 29cc. I started to put it together and the clutch housing bolt are not in the right place. The top two bolts are wider in spacing. I was pissed off. So I took the back of my red cat clutch housing off an tried it and it fit. So when I went to put it in the truck i am having a really hard time trying to get the gear mess right. I have rc max center diff housing that is in and 19 tooth spacer for the motor. When I put it all together the gears are binding. I took out the motor 3 times and tighten it even all the way around. The only way it will work is if I shim the motor up with washer on one side. Tighting the outer bolts first than the inside bolt with the washer. What the hell is the problem. Do you think the rear housing is making the clutch gear to tight. Thanks
