MT first run
ika
Hi,
It was first run of my MT.
Following modification was done:
1. wr-668 carb
2. CPI tuned pipe,
3. changed all bearings(fasteddy),
4. changed diff fluid 10k front, 5k rear
5. installed diff out-drive cups , maiden by local lathe master
6. hostile black boot, bought 12, but install only 4 , it works after cup installed.
without cup little bit larger.
I have not damaged anything and think power and speed is enough.
I like stock steering servo strength and don't understand why you are changing with hitec, futaba, etc..
As i am told newer servos come with better quality, hope mine last long enough.
Have to change spark plug with NGK CMR7H, also thinking power starter by killerrc.
I still have the original steering servos in my MT and there over 2 years old now and still operate fine.the throttle servo crapped out the third tank.
Have you striped gears or fried ?
So maybe its better to get hitec throttle servo....
I've got 2 m/t's and a d/r all throttle servos crapped out very early in the game. the one m/t was on second or third run. steering servo on the one m/t also gave up after just a few runs. the other m/t and the d/r are still running original steering servos and are still going strong but I must say the m/t with hitec replacement servos is the most responsive steering wise of the bunch. in my opinion the throttle servo is what I worry about the most since it's them that can cause these beasts to runaway and possibly hurt someone and that wouldn't be much of a problem if everyone were smart enough to use some type of kill switch. I guess what I'm really trying to say is that if I was you I'd either change the throttle servo or at least keep a replacement on hand so as not to loose a good day of bashing because to many other things can and do happen and I myself don't get enough time to beat mine up as it is.
I got an upgraded Rampage here that came with upgraded electronics, etc.
Do you have pics of your setup? Be curious to see what it looks like Ika.
