My 30lb baby arrived
got the same shock tr brace and full force front brace myself, even have the front supports and x brace are alloy on mine.
don't have a pic i don't think of the rear TR bracket, but its same as yours, only orange
Thanks for the heads up on the heat I can't wait to give this thing a good stern beating and see what gives:w00t: below are pics of my backyard MX track that it is for.
The Wraith used to be king of the mountain
hey car looks awsome an beautiful back yard would love to race my XB with you:cup-1:
No I haven't cut it yet cause I got the CPI pipe but I still have it in the parts bin if I need to:) btw Fedex says the cage will be here tomorrow already bought the P clips to make some .025 aluminum panels similar to the ones I made for this.
34242[/ATTACH]"]IMG_0410.webp
Can't afford that sucker! Do you think I will be alright cutting the pipe and using a coupler? I heard someone mention that it pops the coupler off. I guess the cut ends need to be flanged a bit.
Actually I think it can be pretty easily done if you use the original as the header and some heater hose for a coupler but I think that the bracket is too weak to handle any rough treatment that is why I sprung for the pipe.
Got the cage installed today and clearanced it for the pipe, I already knew that I was going to have to do this and I have an idea for a brace to take the place of the material that I removed.
This thing is ridiculous:)
34252[/ATTACH]"]IMG_0547.webp
34254[/ATTACH]"]IMG_0539.webp
Pipe clearance. Scary cutting on a $190 cage
34256[/ATTACH]"]IMG_0534.webp
34258[/ATTACH]"]IMG_0533.webp
34260[/ATTACH]"]IMG_0538.webp
Thought I would update this thread as it has been a while, The weather here in Oregon has been raining non-stop so I just keep adding stuff it seem until it dries out:)
things added since last update not pictured
Hemistorm Maxhex brake hex
rear RPM arms
SS screw set
DDM 5000 mah battery
angled Shreadstack
Picked up a budget Futaba T3PRKA($69.00) to try out if I don't like it I will demote it to one of my sons scalers:)
34661[/ATTACH]"]IMG_0574.webp
Proline Trenchers on Silverback wheels and beadlocks
34663[/ATTACH]"]IMG_0576.webp
Size comparison to KM/hostile clones
34665[/ATTACH]"]IMG_0577.webp
34667[/ATTACH]"]IMG_0580.webp
34669[/ATTACH]"]IMG_0581.webp
I am thinking Dirt Drags:)
34671[/ATTACH]"]IMG_0578.webp
I finally got to hear the pipe at full song in second gear yesterday and all I can say is it was amazing and scary to realize my brakes weren't adjusted tight enough:) all fixed but compared to the stock 30.5 cc and rear dom clone pipe it feels like it pulls the HP all the way through the RPM's. I can't imagine what it will be like when it comes time for it to be a OBR Prostock.
A little update, after bashing it for a few tanks I took it over the MX jumps and after some "Dukes of Hazzard" style driving I was able to able to find some weak points and fix them approprietly.
Broke KM shock cap from a crash
I decided that the shock cap wasn't the problem it was the suspension over extending and pulling it out of the brace so I got new HPI shock caps and some Killer RC limiting cables.
34843[/ATTACH]"]IMG_0615.webp
I also broke one of the front KM plastic hubs
34845[/ATTACH]"]IMG_0613.webp
Going to replace both front hubs with HPI parts and also rebuild the rear shocks as they aren't as smooth as I would like.
Got the Racers edge SS screw kit aswell
And did the laundry:)
Will post pics when I get them installed.
