- Nj
Blue Loctite on the screws holding the servo horns.
Sounds good thanksBlue Loctite on the screws holding the servo horns.
Not yet just got the pipe on today and ran a tank through it it rips! Throttle servo screw came out have to go to the hobby shop tomorrowGlad to hear you like it ... have you run the truck enough to see if you need heavier shock springs and thicker oil yet?
FinishedIs the pipe raw finish or plated?
Yeah guy at the hobby shop told me about that. Said they look cool when they turn colorsAh ok. Atleast you don't have to worry about coating it every run as I have raw pipes.
Yeah that looks hella awesome! What kind of air filter is thatO yea they absolutely do. The initial color doesn't last long tho but they are interesting to watch ...View attachment 73610
Ok coolThe red is a TGN redneck dual stage pre filter.. the actual filter is a uni 3" filter
I recommend as much protection between the air and the main air filter .. I have an outerwears pre filter,the tgn dual stage and then the uni
I’m going to the hobby shop tomorrow morning to see what they have. Thanks for the infoThat would be my #1 next recommendation which is to upgrade your filter asap and especially if you run the truck in dusty conditions and pick up a quality name brand foam filter oil
Yeah that’s where I got the two stroke oil atAnytime also foam filter oil can be had at your local dirtbike shop or dealer. It doesn't have to be strictly rc related
