I finally got around to cleaning the e-DR. I ended up removing all the electronics and hosing it down. It was the only way to get all the dirt/mud off of it. I then sprayed it down w/ WD40 and wiped it off. It looks like new w/ one exception......the tranny didn't fair too well.When I took the gear cover off the gears were a little wobbly. I took the gears off and noticed that the aluminum hub for the clutchbell gear was seized on there and the pin holding it to the shaft was halfway out. That pin broke in two and wedged itself in there. I had to pry the aluminum hub off. The next gear to it had the same issue but the pin didn't break. But it definitely looks too short. Regardless of this, the gears just don't mesh very well if I tighten down the nuts holding them on the shaft. They need to be a little loose to spin freely but then they still wobble and have tight mesh points throughout the rotation.
Are these gears, shaft pins, aluminum hubs, and gears a known DR issue? Any advice is appreciated.
