BoukeG
Nice, thanks for sharing!
Wow, those should work.mulepic said:
Thanks! Bookmarked.mulepic said:
The thingy is the gear plate.mulepic said:Pulleys showed up today!!! The belts arrive on Thursday. I'm not going to jump into that one till next week. I need to figure out how much permanent modification it's going to take to pull off. I'm pretty sure I have to do make changes to the gear case/wall thingy that holds all the bearings. Or maybe I make a new one so I can switch back to gears quickly in case there's an unexpected track opportunity.
Awesome. Keep us updated on the gear plate! Curious to see what you come up with.mulepic said:I just drove it around my street for 4 mins doing as much WOT as possible. The temps were lower than I've seen them but I'll reserve judgement till I can do a full battery test. The nicest feature about the motor fan is I can leave it running when I'm done driving and let the motor still cool down. If that fan survives the dirt I might just get another one to put under the ESC to do the same.Pulleys showed up today!!! The belts arrive on Thursday. I'm not going to jump into that one till next week. I need to figure out how much permanent modification it's going to take to pull off. I'm pretty sure I have to do make changes to the gear case/wall thingy that holds all the bearings. Or maybe I make a new one so I can switch back to gears quickly in case there's an unexpected track opportunity.
Ahaha. Congrats!mulepic said:I just noticed I'm now a senior member. And to think I started this build just over a month ago.
