G
Guest
Guest
Redcat currently does not offer an aluminum cage for the DR.
That's a neat idea. Did you just dab some on the outside of the cup over the pins? I would think there would be too much movement.rampagemt said:I used shoe goo on my cvd and it held pins in nice. I haven't experienced a cup breakage like that
That basically says they're usable but no expected lifespan warranty.mulepic said:One other issue I ran into at the track yesterday is my brand new battery pack seems to have been faulty. One of the cells in the pack wouldn't quite charge as well as the others. And after running it that cell dropped to 0.0v. There's not much I can do and the warranty on lipos is pretty bad. Here's part of it from hobbyking: http://www.hobbyking.com/hobbyking/store/lipo_policy.html"Please keep the following in mind before making a claim;
We check all battery pack voltages prior to shipping. It is a simple process and takes us 3 seconds per pack. Doing so assures us that the battery is fit for use, is within the voltage range and has no shorting.
This process does not remove slightly unbalanced packs.
1) You can only make a claim for 'Under voltage' the same day the parcel arrives and prior to the lipoly pack being charged or cycled. 'Under Voltage' means that 1 or more of the cells in you pack has a voltage lower than 3v per cell. After the battery has been cycled or used, no claim for 'under voltage' can be made."
I'm not too upset b/c I was actually of thinking of getting a extra 6s pack because I'm considering running 14s vs. 12s. I'm hoping the two extra cells get me to the >30min runtime. Right now I'm at 25-27mins. I'll break out the cells from my current damaged pack to get to 14s.
On smaller cars I've done this. I put a very little on the pin, like a hair of it, then slide the pin in. I can't tell you how many different ways I've used shoe goo.RCDAD said:That's a neat idea. Did you just dab some on the outside of the cup over the pins? I would think there would be too much movement.
I like to use it for air freshener. Hahahamulepic said:I can't tell you how many different ways I've used shoe goo.
The other issue is the 5 other cells in the back get discharged by the esc too much to make up for the lost voltage. Luckily I was able to recover the other cells.RCDAD said:That basically says they're usable but no expected lifespan warranty.
I hear that! Those aren't the standard packs either, your buying huge packs.mulepic said:I just ordered a new pack, for anyone keeping track I'm up to 5.....I didn't say 'E' was cheap.
They can slide and push the shoe goi a little bit but it held up nicely once I used it. I didn't put them fully through there paces as I was looking for dogbones and axles as I think it is more bulletproof then cvdsRCDAD said:That's a neat idea. Did you just dab some on the outside of the cup over the pins? I would think there would be too much movement.
