Rickdragon
This is a list of the modifications that I have done to my Full Aluminum Baja 5B.
30.5cc ESP race ported 4.5hp modified engine. Walbro 990 carb, NGK 8HIX Iridium spark plug.Lightened flywheel, MSD spark plug ignition wire kit, DDM 1" velocity stack,TGN angled "shortstack" air filter, outerwear prefilter, outerwear crankcase filter, chrome engine kit.
Turtle Racing V2 pullstarter/ aluminum cog, ball bearing dog cage, stainless steel guide, and Integy handle.
Fullforce fuel line kit, Darksoul fuel line disconnects.
TGN carbon fiber insert aluminum gas cap.
FUTABA 3PMX Radio with 11.1v 3s Lipo battery, Savox 0235, steering servo, Savox 1258, throttle/brake servo. Killer RC Kill switch, Smart voltmeter, 4200 mAh Lipo Rx Battery,and Hpi light controller.
TR V2 HD clutch system.
DDM V2 Dominator rear mount pipe.
DDM Black Magic 18/56 gear set.
Aluminum Diff case with HD alloy Differential.
TR rear upper chassis plate and one piece brake mount.
Full Force Carbon fiber and. Aluminum brake upgrade kit.
Python polished gear cover
with Baja engraved cover plate and rear wing mounts.
Hostile Racing oversized bearing one piece 2 degree rear hubs.
FLM HD hardened drive cups.
Zoni Racing HD Titanium Dogbones.
IRP rear upper Heim joints for the Hostile hubs and Heimicuffs.
Overkill concepts upper Ball ends.
IRP front HD turnbuckles and steel wing joints.
Uber RC aluminum front and rear axle extenders.
Threshold aluminum front bulkhead.
RD Logics aluminum rear bulkheads.
TR one piece HD front shock tower w/ KM supports.
Kraken V2 Titanium hinge pins.
8mm big bore piggy back shocks w/ shockwear covers.Killer RC shock limiting cables.
Jetpro chrome nerf bars.
Integy aluminum radio box, Steering bellcrank, roof plate with Killer RC LED's, Integy Rear wing, Front light pods with killer RC LED's, Killer RC Rear red LED's and mounts ,4 CST light pods not yet installed.
HBZ chromoly chrome front and rear bumpers.
Modified RC HD Rear chassis plate.
Modified RC quick release roll cage system.
Modified RC front chassis support.
Aluminum (Fullforce) cage risers, side body pins, front body pin, and wing pins.
Aluminum engine and roll cage mounts and front and middle supports.
Proline custom painted desert rat body.
Custom made real window nets.
RC screwz stainless steel screw sets.
Hostile MX tires and dual material, zero growth inserts, mounted on Aluminum "Orbit" wheels. Integy aluminum solid wheel nuts.
And last but not least a Replay XD1080 camera with custom front mount to film the fun.
