gool, will these new style cups fit the MT V3?RampageHopUps said:Yes, the copper colored are the new process for hardening.
Does the entire diff assembly come of the car in order to change the oil inside?RampageHopUps said:3k in front, 4k in rear.
yes , diff box off unit, open box, and then open planetary caseIce_2k said:Does the entire diff assembly come of the car in order to change the oil inside?
LOL!phreerider said:only thing better than a package is packages AND boxes!
Isn't that crazy? lolIldy666 said:Man time flew by it only seems like page 8....lol....
You can always weld using metal tubes, it will give you more of an agressive look than bendingdesigned2survive said:Is there anything more to it than just heat with torch and bend?
It would be cool but unfortunately I don't have a welder . I was referring to the ABS plastic as I have never dealt with one. I was thinking cut, heat it up and bend it to shape.Silent_chaos said:You can always weld using metal tubes, it will give you more of an agressive look than bending
Cool! Will try that! Thanks!phreerider said:ABS plastic , can be heated with heat gun and shaped. EASY with the heat it will blister on surface as it approaches plastic stage . slow and even . a holding jig or form makes it easier.
