Buster dog
New Member
- Reaction score
- 0
I have recently purchased a Rovan Baja with the 30.5cc engine in and I am experiencing problems with it, I haven't even got it run in yet I have had it ticking over 3 times but while trying to start it again the pull starter failed, so I have replaced it but I can't get the engine to start now, I first thought it was an electrical problem but I am now convinced it's fuel starvation cos the engine will not fire using the recommended starting method but if I hold the throttle wide open and try to start it the engine attempts to fire, I need some advice on what the problem could be, firstly how is fuel drawn through the carb does it work on vacuum or suction method, basically I just need some advice on what the problem could be ?
