Harold Bascom
- Reaction score
- 370
My Zenoah G290RC began bogging down badly every time I applied heavy throttle. Having read that when this happens it's an indication that the Low Speed Needle (LSN) is too rich and an overwhelming amount of fuel is being dumped into the combustion chamber, I began leaning it out by gradually by turning the needle clockwise in small increments. That didn't stop the bogging.
Another post prescribed leaning out the High Speed Needle (HSN). That didn't work either; the bogging down continued. It was a 'wits end' moment.
I Googled some more opinions and stumbled on something I never knew and hence the reason for this share, just in case there are others like me. Lol.
A response said that the problem was in the oil in foam of my air filter; that it was oversaturated, and that everytime I grabbed a handful of throttle, the oil from the air filter got sucked directly into the carb and caused the engine to bog down. (The truth was, the day before, I oiled the inner foam pad of my air filter and had a sneaking suspicion that I put too much filter oil on it.)
So, I took the oiled foam pad out, pressed it between wads of paper towel, and got the oil out. I then looked into the cavity of the air filter, there was an obvious amounta of oil in it. I swabbed it out. I put the filtering system back together, reset the needles to factory, and guess what?
The bogging stopped. PEACE!
