The manual that came with mine is pretty much garbage when it comes to looking at the diagrams. Looks like a copy of a copy of a copy x100.....Deluge said:
If you pick the truck off the ground and spin 1 wheel at a time, do all 4 wheels spin when you move 1?XDEEDUBBX said:its not the brakes cause they are not catching. in the video you see the truck moving forward but thats already at half throttle and if I were to keep holding the trigger down it will go no where.
I will try that this weekthe1320god said:If you pick the truck off the ground and spin 1 wheel at a time, do all 4 wheels spin when you move 1?
Do you have any pics of it, that will help me out a lot thanks..HBD8TRCR said:make sure the pinion is moving freely on the ring on the center diff , make sure the set screws are tight on the pinion ( mine were loose from the factory) if the pinion is in a bind on the center ring this would cause your problem.
Do you have a pic or diagram of this as well? thanks.tsudo5th said:I had this problem. The pin that goes through main gear off clutch broke. Pull off gear and remove the o ring to check if your pin is there.
help please!xdeedubbx said:i will try that this weekdo you have any pics of it, that will help me out a lot thanks..
Do you have a pic or diagram of this as well? Thanks.
I will try and work on it this week, been busy with building my e-revo with a big block in it.. =)
Sorry for all the noob questions but the above pic your referencing is inside the actual clutch?Deluge said:The A gear. The gear that rides on the clutch bell shaft. Take the gear off, and remove the o-ring from the gear mount. There's a pin that goes through the middle of the mount and the clutch bell shaft, make sure it's there.Here's a pic of the assembly...
You have the 4 pin gears, right? That's the hub that the gears ride on.XDEEDUBBX said:Sorry for all the noob questions but the above pic your referencing is inside the actual clutch?
The top diagram shows the center diff. That's where the crown gear is at. The bottom diagram shows the brake hub. That's the part that your brake discs ride on.XDEEDUBBX said:And where is this part located?
^^^^ He pointed it out. I just clarified it.tsudo5th said:I had this problem. The pin that goes through main gear off clutch broke. Pull off gear and remove the o ring to check if your pin is there.
