KrashKrieg
Hello all you boat fans!
I was given this awesome Apache Gas boat...that's it in the back of my Chevy HHR...
It measures 57" from (tip of) bow to stern. Is this an Apache 56?
Does anyone know where I can find a manual?
Even though it hasn't been run in like 10 years, the motor turns, and everything else looks in good condition.
I have to put in a new battery, put in my radio system, fix up the wiring, new start switch, better seal on radio box.
Being a first time boat owner, i'm not sure of a few things and maybe some of you can help.
I'm pretty familiar with Truck Gas motors but this boat setup is kinda different.
How do you put gas in these things? Is it that valve near the pull start in my pic?
...if so I guess you use some sort of a pump to get it in?
I can't tell the cc of this motor, but I guess it must be a zenoah.
Can I just put a new carb on this instead of cleaning this one? If so which one?
I can't seem to see where the water (for cooling) comes into the lines?
How do I grease the shaft? what type of grease?
What else should I do before trying to start / run this thing?
Thanks for any/all your help. Can't wait to see this beast fly!
