Not impress with my Hitech HS-5755MG
regarding my new battery, how do I take care of it? I charge it over night and maybe run my XB for like 1hour and stop.... and then might not be able to run until next week. Sometime I run it 1 hour or more and twice a week. I don't have a voltage meter thingy... so how do I take care of my battery with out overcharging it? Is it safe to charge a battery that is at 70% charge? should I charge 4 hours instead of 8 hours because its already 70% charge?
It's ok to do partial charges. Your little Redcat charger won't over charge it. Maybe once every couple months you can cycle it. Fully drain the battery and recharge. Do the a few times when you do. It's easy just pick up any 12v automotive lightbulb. They work great to drain the pack.
Got pic? What kind of connection does that particular light bolt have?
I don't have mine any more. I have a charger that will cycle a battery for me. Just head over to your walmart, go into the automotive dept., and pick up a trailer marking light. It will be in a housing with just two wires sticking out of it. You can just install a plug that matches your battery onto the two wires.
I see, awesome :D .... maybe I should buy me a charger... which one do you recommend... simple... good quality and cheap?
Run the battery until it's dead. Then you won't have to rig up something to discharge it. You won't overcharge it, dude. The stock wall charger is only putting out 250mA. You'd have to leave it on the charger for 30 hours to overcharge it.
By the way, I did my math. You should be leaving the battery on the charger for around 24 hours in order to get a full charge.
Very happy with my Onyx 200. Been using it for years. If you just want a charger for NiMH's, this would be a great option. You can get it for around $40.
Do I just plug it to the wall? Any other accessories I need to get?
