G
Guest
Guest
Did ya place your order yet.ChuenouXiao said:THANKS! appreciate it![]()
Not yet....RCDAD said:Did ya place your order yet.![]()
Deluge... does this charger that you recommended... does it do discharge on battery?Deluge said:Yep. Comes with everything you need.
The nickle batteries do better when run all the way down. If you run them down by just driving, you will start glitching out at around 4 volts. There is still juice left at that point. Just not enough for the receiver and servos. The nickle batteries can develop a charge memory. If not completely cycled they will eventually not take a full charge.Deluge said:Too much hassle. Much easier just to run them down.
nicd batterys will develop a memory i have never had a case where a nimh did i have used reciever packs for a couple of years with only topping them off with no issues and i even leave them sit all winterRCDAD said:The nickle batteries do better when run all the way down. If you run them down by just driving, you will start glitching out at around 4 volts. There is still juice left at that point. Just not enough for the receiver and servos. The nickle batteries can develop a charge memory. If not completely cycled they will eventually not take a full charge.
if you are not going to run the lipo for a while i would only leave them at like 50% capacity also try to keep them in a cool place, i have seen more lipo's die in storage than nimh batterysRCDAD said:I've had the fail just in storage where I can no longer get them to take a charge. That was my main reason for switching to lipo RX packs.
That's correct. I use a 12v automotive light bulb to fully discharge my NiCD and NiMH packs. I've been doing that for years. No problem yet.RCDAD said:Is this not correct? I'm only as accurate as my teachers. LOL
