Nurchburgler
- Thread starter
- #21
Bet!Obeast44 said:The diffs themselves are the same ones in the MT/TT....the only difference is they opted for only 1 set of spider gears instead of 2. Its mainly just for weight/cost savings.
I went back to the original setup..an did what you said mang..much better...not as smooth as I would like but....it will do.
What oil are you running in your diffs.
I went 15000 front and 10000 rear.
Seems a bit high but without a center diff I figured this should be appropriate.
