Oil next to plug on the head??
Peteolheadz100
Everytime i run my car i notice there is a little oil around the spark plug, what is causing this? Spark plug is on tight , don't know where it comes from?
You might not have given the washer enough crush on it. You need to tighten them pretty good so the sealing washer can do its job. It may feel tight but you might not have it tight enough for the sealing washer to work. Adding sealing will now cause the possibility of it not grounding or having a bad ground and not ignition firing issues.
How tight should these be torqued down, i turn until its snug hsn give about 1/8 turn, seems pretty tight, again i wouldnt want to strip the threads
The stock plug that came with my motor looks almost flat, not to mention that plug when snugged down it keeps turning like if the threads are stripped , i bought an ngk plug and this one doesn't keep spinning but im afraid of over torquing it and damaging the aasher or threads...
