Kevin Cabral
Is it worth buying? I purchased the pull start cover, it should be at my doorstep soon. Some people are saying I need the crankcase cover as well. Or dust, sand and so on will just get stuck in the pull start cover area. Is this true? Or should I just not put a pull start cover on anyways? I assume without the pull start cover on, it's safer for debris to pass through the flywheel and out from the pull start vents. What do you all think? Any help would be greatly appreciated.
Thanks in advance.
Thanks in advance.
