Outerwears Crankcase/Flywheel Cover?
Kevin Cabral
Is it worth buying? I purchased the pull start cover, it should be at my doorstep soon. Some people are saying I need the crankcase cover as well. Or dust, sand and so on will just get stuck in the pull start cover area. Is this true? Or should I just not put a pull start cover on anyways? I assume without the pull start cover on, it's safer for debris to pass through the flywheel and out from the pull start vents. What do you all think? Any help would be greatly appreciated. :)
Thanks in advance.
It's actually really good. Problem is I have the stock exhaust. Oil splatters all over the cage cover. I soaked it with WD40 then cleaned it with fish soap. Rinsed it. Looks brand new lol
Have destroyed a few flywheels by not installing/covering the vents under the engine.
Do the typical mesh mod.
If going this route, hold the mesh in place by using glue gun in certain spots, then apply M600. Patience goes a long way with this diy.
