buzzkill
Mad?scientist
How about this , we do a Pipe Shootout ?? compare all these high end and stock pipes on the same motor No changes except the Pipe ??
1. use a 32cc motor ( we can use mine )
2. ONLY change the pipe
3. run it several times and adjust for temps humidity. etc. ( I'll record them )
4. see what we get , I will record load , rpm, EGT temp ( Exhaust ) amb. temps ,humidity
5. i'll make the throttle programmed so it is the same for each run.
Just a thought ?
Any suggestions ?
Just a thought ?
Any suggestions ?
