G
Guest
Guest
Just a FYI the Xseries C & D gears are 24-26. The MT, DR & TT use the 25-25.
I think my xb is 29/31/25/25RCDAD said:Just a FYI the Xseries C & D gears are 24-26. The MT, DR & TT use the 25-25.![]()
Is this correct . It makes sense.rampagemt said:If you swapped a and b gears you would have 35 25 25 25
Do you have a higher rpm clutch spring installed?creepingcharlie said:Just a tiny bit. It took a little longer to get to higher rpms.
