Spoogity Woogums
- Thread starter
- #41
Can I get a list of screws for the engine mounting and gear plate? The guy I got it from stripped most of them out. Also, how the hell do you get the pinion off?
Thats what the cop said. I thought he was coming over to harras me. He just wanted to know what was in that thing. He showed me the gun and it said 55. G290, 813 carb, rear dom, 19/55 gears and hostle mx rear tires. You gotta remember tho that the baja is only 2wd so there is a lot less rotating mass. Also i run on high octane with the motor slightly rich so the plug is about a dark brown.You got 55mph from a stock 29 and a 990 carb?
A lot of different size screws. Would be best to download baja 5b parts listCan I get a list of screws for the engine mounting and gear plate? The guy I got it from stripped most of them out. Also, how the hell do you get the pinion off?
So I got the engine out, and took some pictures. The cylinder itself looks clean from what I can see, but until I get the right tools to take it apart, It's fine as far as I can tell. The fly wheel has missing fins, and the muffler was beat to hell. The piston however, I'm sure was destroyed by the electrode that broke off.
MY NEW PROBLEM: The guy who built this must have used an impact drill, because I could get all but 2 screws out, so the clutch bell housing is sitting with hexes that were stripped out by an idiot with an impact drill set to 11. So now the Clutch bell, Clutch bell housing, and the gear plate also has a stripped screw. Since I'm going with the G320, recommendations for clutch bell/housing?
I wanted to toss it, but my younger brother back in oklahoma wants it because he's like a mix of grease monkey and mad scientist. So he's gonna get it next time I see him
And I know it (G320) has a clutch, I need a clutch bell and the part to hold the clutch bell
I'm not understanding which part you mean.
Have you got a pic.
My previous post should have said If you're putting it in a Losi
The clutch bell and the housing, the part the clutch bell goes through. The ones I have aren't coming out anytime soon.
Blue is the housing/carrier I need, Red is the clutch bell itself. Both need replacing and I need recommendations
