Question regarding LiPo use.
Chillin4life187
Finally switched over my Baja 5b to high voltage savox (throttle) and Hitec(D845wp) servos and using a Futaba 4PV radio. Im looking to buy a compact hardcase LIPO battery. Can anyone tell me what kind of run time to expect with a 2000-3000 mah lipo vs a 4000-5000 mah. My goal is to keep it hardcase and relatively small in size. With a milion different brands and sizes im not sure which way to go with this. Any input is aporeciated.
This is what I havr in mind;:
https://www.ebay.com/itm/TURNIGY-TR...:UmAAAOSwj~9bkRuu??USPSFirstClass!85302!US!-1
OR
https://www.ebay.com/itm/Dynamite-R...717300&hash=item48a3524440:g:UNcAAOSwHZ1Z3RH~
U won't find a hardcase
what will fit in the rx box?....i can get 3-4 tanks atleast from my rx lipos ?
And 140c is way to high for a rx lipo...u only need 10-20c....and the biggest mah what will fit in the box ?
Atm mini i run a 6.6v life in my baja...only because my £75 savox throttle servo is only 6v rated.....its this one
https://hobbyking.com/en_us/turnigy...KDBxoCHVoQAvD_BwE&gclsrc=aw.ds&___store=en_us
I can do 3 tanks on this...?
Once i change the throttle servo to a hv one i will b fitting this one?
Although i may need the killer rc taller lid?
Great. Well that gives me an idea at least. I have a 6.6 2100 LIFe pack in mine as well. Works well for the most part. I was lookkng specificslly for the hardcase becsause I don't know of any LIPO that will fit in the box so I was going to keep it outside of the box...i figured something durable would be best. I do have the taller box from killerrc and it makes a huge difference. Unfortunately your still limited on room and I haven't found a decent size lipo that will fit. The taller lid from killer rc is about an inch taller if that helps you any. Posted a couple pics.
OR
Be careful with the second option I bought one and the small red led detached after 4 or 5 times out with my truck.
