berto1230781
- Reaction score
- 0
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.71/.f or any of these http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.6099/.f if i were you i would try a different reciever in your truck. you mentioned you have a tmaxx i believe. if you don't have problems with it try putting your rx from that truck in your rampage first before you go spending money on the wrong thing. i would try to figure out what component is causing your problems.you could also try unplugging your servos one at a time with truck running and see if your problem goes away. i once had a tmaxx that got water in the steering servo and it caused some weired feedback with the reciever anytime i moved the front wheels on the truck by grabbing them with my hand. the throttle servo would glitch badly and the truck would try to take off. do a few expariments and see what you come up withberto1230781 said:no i don't have then in foam should i ???? and kent from killer rc said the same thing could be there battery so u say factory battery that came with it it's no good they have problems with then if so what kind of battery do u recomend thanks
