RCMAX 7075 Front end Parts for the Baja ?
Sticky stuff huh ?
It takes 6-8 flute end mills with special coatings and a machine with extreme rigidity. If you don't have one of those atleast, you might as well throw in the towel. Or spend 100x the amount of time taking extremely slow and shallow cuts. Vibrations is what kills a cutting tool before the run even starts
I have limited experience with it. One of the tractor puller guys wanted the machine shop I used to work for to make rocker pedestals, rocker arms, and retainers for his engine. One of our best guys tried it out. Programming went well enough. Couldnt keep bits in CNC. Tried on the bridgport. No love. We were just out of our element. Obviously we couldnt charge the customer for what was attempted. Ended up sending the work out to a company that specializes in exotic metal machining. The rocker arms didnt work out well. For some reason the push rods ate through the pocket. Everything else worked out great. Actually has made me stay away from titanium in any more engine builds. Just don't understand it enough to trust it. ?‍♂️
I specialize in exotic and hard metals ??
It takes extremely shallow and small cuts which equals tremendous cycle time.
(more cost, tooling, etc) unless you have a machine that can handle it. Bridgeports are a no go lmaooo ?????
Makino has a new 5 axis machine specially for titanium machining. They are doing 5/8 depth of cut with . 125 step over and still running at 200 inches a minute and having fantastic tool life. If only I could afford the 5 million for the machine lol
Place I used to work at had 5 of them attached to a multi pallet system that kept it running 24/7
You could smell the $$$ I swear ??
