RCR Brake Kit
Picodogg
I eat DDM chocolate mints for breakfast
PLUS member
Kansas City
Anyone have any experience with this kit? It says it will work on 5T 2.0.
Stock brakes are fine…. Although I got some WD 40 on them. Kind of a surprise when you are flat out and expect to be able to brake and slow down at a normal distance.
In order for you to use the rcr brakes on a 2.0 you need to open the holes on the copper pads to the size of the slide bolts and you can no longer use the springs as 1.0 brake disks are a larger diameter and thicker than the 2.0. Not really worth it. If you want good brakes get MOD brakes, I have them and they are more brake than you will ever need. Is it really necessary no not really the stock 2.0 brakes are more than enough for bashing.
