Streetwise
Hey Guys,
I've had the rear alloy brake holder and large fibre disk set up for a while now, and im thinking of upgrading to cables on the rear, i already have cables on the front.
Heres the question; What is the benifit / advantage / disadvantage:
Of the layshaft free wheeling, or not being under load with the spur gear and clutch gear with the rear cable brakes under braking as compared to braking with the standard brake system which directly brakes the gears ??
The Large fibre brake disk is well worn, the centre hub is starting to round off as its had alot of use.
Are the rear cable brakes worth investing in for better braking ?
I'd appreciate your comments from those that had made this change and were you glad you did it !
Cheers guys
Cheers guys
