phatdad
Short and sweet. Before you run it snug up all your fasteners and check your spark plug. My plug was about 3 full turns from being seated. Fuel up time. I always run 28-32 to one oil mix. Pump up the bulb,chock on,about 5 pulls and it popped,chock off,second pull started right up. I leaned high and low just a little.Ran the buggy for about 10mins on the flat. Cool down,start up first pull readjust carb,pulled off the power robbing stinger and went on the track. About 5 mins later the buggy turned into a pogo stick. No big deal because I did not like the suspension set up anyways. All 4 shocks had broken c-clips. I replaced them with a larger HD clip. HPI HD clips snap right on as well. I lowered the upper shock positions front and rear about 5/8" down on the mount to get more down travel below the chassis. Added 40wt oil front and rear, replaced the front shock spring with a HPI blue lower rear.Went back on the track and what a difference with a little suspension tweaking. The buggy went threw the bumps and jumps 100% better. I was running the stock motor with the stinger off and I was impressed. You need to keep it up on the power but the buggy got around great. I hope Redcat has some gearing options. If you run a larger motor you will want them. With some more track time suspension tweaking and more power this buggy will get you hooked. Nothing is funner on a track than a 4wd buggy especially one that has a gas motor. I also went threw two tanks of gas before it got dark and after the small amount of set up changes I did to the buggy, it ran great with not one problem. I was impressed with the shocks. They are simple,did not leak or bend and shock fade was minimal. I'm going to service the diffs and drive train next and look for any signs of wear or week points. I will keep adding to this thread as time goes on.
HPI hubs are a direct fit. Thats great news because my stock tires only lasted about 5 tanks of gas. The stock wheels are strong as hell and much better than the HPI wheel but there is nothing protecting the side wall on the stock tires. The tires take a direct hit on the wheel.
