enzo3856
- Reaction score
- 220
Finished up on Baja 1, now onto Baja #2
Last time she ran in the fall she had some issues with the rear A arms.
The wheels grinded them down so the shock shaft popped out.
Here is the plan:
Front - general clean up, install FFRC tower brace, install Darksoul V2 extender
Main chasis - clean up, cover up frame openings, clean gas tank, replace gas lines, FFRC window panels
Motor - clean up, install outerwears on bottom of motor, fix sticky kill switch button, vertigo bell housing, Dominator FAST pipe
rear - upper and lower RPM A-arms, ALX brake hub, replace broken shock shaft, Darksoul V2 axle extenders
Hopefully all this should make it bullet proof for this year. Out of the 2 Bajas this one is the most dependable, so I want to keep it this way
*NOTE* this was mid year last year... should have taken a before pic as it was grungy from the last runs
Here is the plan:
