remove screw
Discussion in 'Tutorials and How-to's' started by smartech uno, Jul 12, 2013.
Tags:
  1. smartech uno
    smartech uno Well-Known Member
    Jul 23, 2012
    116
    0
    Israel
  2. Guardog8
    Guardog8 Active Member
    Feb 10, 2016
    32
    15
    Williamsport Pa
    dremel cutter wheel and carefully cut head of screw so that you can make a groove to fit a flat head screwdriver in it. Other option is to drill out but that can create more damage if not careful
  3. WoodiE
    WoodiE Kind of good admin.
    Staff Member
    Feb 13, 2007
    1,592
    38
    Kentucky
    MonsterAir likes this.
  4. William E Burrows Jr
    Mar 3, 2017
    18
    3
    Florida
    All four of my motor flat head bolts were stripped, I made the mistake of using a tiny amount of blue thread locker.
    The heat turned the thread locker into a permanent bond.
    I bought the speed outs from Home Depot for $21.00 they are titanium coated.
    The bolts were to hard to drill a deep enough hole for the other end of tool to bit in the bolt to remove.
    I return the SpeedOuts. Plan B. I purchased a carbide drill and a harden steel easy out and mounted it in a hand chuck. Success! Bolts removed. The SpeedOut extractors work great for medium soft fasteners but my problem needed old school machinist tools.
    Best Regards ,
    William E. Burrows Jr.
  5. Whoduh
    Whoduh Well-Known Member
    Mar 25, 2014
    148
    27
    Fairfax, VA
    I've had some issues screws...blue threadlocker and all...speedouts worked for me. Heating the screw up with a butane torch helps alot.
    WoodiE likes this.
Loading...
