Doggydogg
- Hillsborough northern ireland
Suppose I really should have gone to school more
I can play pool tho ! Lol
for you so we can help you
1. Are you sure your stop button has broken ?--its not broken but If so how do you know this ?
2. Did you set your high and low speed needles to factory settings as I put up the factory settings for you for your engine and also tryed it myself to be sure ! - I do not understand how to set any video you have\picture?
3. Did you put in a new spark plug ? -i replace it with new spark
4. Did you check your exhaust and air filter are tight and ok ?-air new with oil and clean (type fg air filter foam) ,exhaust -sorry what i need to check?
5. Did you try fresh fuel -no, i make it before 4 days
6. Did you screw in your idle screw to keep the revs up as you are at factory carb settings ?- yes
7. Is your fuel primer bulb filling with fuel ?-where i pump ? yes its full with fuel
8. Make sure your stop button isn't clogged with dirt and isn't stuck in ! -that the Reason that i need to open the engine cover
9. Are your fuel lines ok ? -Even spilled out
10. Did you check for spark-no spark (i replace with new )
What recommendation how to start a cold engine with : open chock or close?
Close choke :Sure?At this point I'm not supposed to open?Prime bulb, close choke & pull until it tries to start. Close choke & pull again & should start within 2 or 3 pulls. Simples!!
I'm glad you got it going mate ! Happy driving now !
Drive it like you stole it !
