ROOF LIGHTS MINUS ANY RECEIVER HOOK-UP HASSLES!
Harold Bascom
#1: Buy a set of roof lights. I picked up the following from eBay: AX-506W Multifunction Ultra Bright LED lamp for 1/10 and 1/8 RCHSP Carv18G7. Price: $8.22.
#2: Buy a pair of 9 volt battery holders with on-off switch, with lead wires. I got a pair from Amazon though I only needed one. Price: $6.30 Amazon Prime.
#3: A 9-volt battery
PREP:
#1: Snip off the receiver plug.
#2: Cut the BROWN wire--eliminate it altogether.
#3: Attach the RED wire from the 9-volt battery box, to RED wire from the lights bar.
#4: Attach the BLACK wire from the 9-volt battery box to the YELLOW wire from the lights bar.
#5: Install a 9-volt battery into the box. Swith it on. And you have lights.
PROS:
No receiver battery drain.
CONS:
You have to manually turn on your lights. The 9-volt battery is a bit of added weight.
