Well here's the story,my 5ivet has stock motor with outer wares on air filter and pull start and a Bartolone big bore pipe.when it's cold it is very hard to start(20)or so pulls while choking it at the same time.so I pulled plug to see if I have spark and I do..plug was also a bit wet as it should be..when I do get it running when it's cold it runs great super fast with my pipe..as soon as it hits 160 degrees it wants to shut down like it's not getting fuel,I watched the fuel lines as it idles today and seen that the primer ball on carb goes completely dry and the black lower hose on carb collapses like a vacuum is sucking the lower hose shut.it is pinching the hose right at the fitting on carb.there is fuel in yellow hose going to top but it's not circulating through..tomorrow I'm going to swap out the poop stock fuel lines and see if this fixes the problem..anyone else have this issue or could it be something else?also today I rebuilt the carb thinking it was all gummed up but it was squeaky clean inside.still put new parts in and cleaned really well.please help....I don't know why it won't run when it gets a little warm...that's all I could find..thanks everyone.
