Lawsi, you used a nylon spacer to mount your shock which is similar to what the 5ive uses instead of the ball. How is that working out? I am getting ready to mount 5ive shocks on my DBXL and have to go that route. I am thinking of using a 6mm bolt with fuel line??? There are carbon shock towers available now that would allow me to use the factory 5ive hardware but at about $70 each, maybe not!
Kinda straying from the shock topic but Lawsi, did you adjust your throttle end points on the controller? I noticed on mine that there was way to much travel. I could hear the servo buzzing. It was trying to pull on a throttle that was already wide open. If you haven't done this, this is probably the cause of the burnout. Maybe not......just sayin lol k now back to shock talkI should try. I already emailed them about the throttle servo that fried up after 2 tanks...
