hi guys, quick update ...
Ive began to fit the parts,
Suspension Arms are excellent, solid & fit with no issues so far.
The Hubs are a no-go! ..the FID hubs are about 3mm thicker than the stock ones, so you cant use the stock drive cup as the pin hole to attach the wheel hex do not line up!
I purchased the hubs with the FID Extenders & came with FID drive cups this solves the problem of the pin holes lining up, but the issue now is the FID pin holes are 5mm & the stock is 4mm, and the FID shaft pin also is too small to fit the stock dogbone of the 2.0!
So as it stands, the FID hubs seem to be a no go, ive emailed where i bought them from & also FID racing as both advertise that they fit the 2.0 gasser...which they don't!
So i may well be returning the hubs for refund & i will purchase the Vitavon Hubs as these i believe are a straight swap wit hthe stock so will work with the stock drive system etc.
As soon i get make a start on the rest, will keep you updated.
will post pics soon
