spur gear
Ebay type In firehammer . They use same gear cover amd there only 4$. Fg covers are 35$ and there exact same. Maybe different plastic compound iam not sure but work just as good
i could not afford the lexan cover so made my own :rolleyes:
i don't like the full enclosed design reason is heat and crap that gets
in:w00t: cant get out
k....
very nice
mine don't look llike that want ltos of ally but money is the problem got new spur on the way and got no work at mo so should get to play soon did get some wicked air before it broke. and the rear arms are def the prob and are very flexy and ties have popped out of plastic ive glued the in with loads of locktight but they def gona be first ally upgrades.
and gaurd designs are under way.:w00t:
Andy its a zenoah 27.2 and ticks over pretty good lol
k....
Nice :cool2: Give me a shout next time you out. I bought a CY off Andy (CSR260) with a DDM 26.9 ported head and cant wait to give that a run!! I would imagine it will go quite well with the FG tuned pipe......
got to play
for a short while spur gear arrived went over skate park had some fun when i eventualy got it to run right due to engine being loose causing throttle giving me loads of greaf doh! then i did a bit to big of a jump after i left the skate park and moved to the safe big empty feild with a banked path around it crashed and engine bolts gave in wrecking my diff gear lashaft gear and new spur gear oooppppssss!!!!
so now need a new gearbox and engine mounts i hate plastic bidding on full ally rear end and shoping for the rest need to sell some laptops need money before my girlfreind finds out.:w00t:
