Thanks that looks like it would do well. Do you have experience with this?You can try a rigid work support.
https://www.homedepot.com/p/RIDGID-...bi6PCfD6grwDvWRKiIoaAmgYEALw_wcB&gclsrc=aw.ds
Thanks these ideas are starting to get my brain thinking and just before bed lol.Get a keyboard stand or make one from a speaker stand.
No but I got the idea from a youtuber that says its good.Thanks that looks like it would do well. Do you have experience with this?
Thanks for the video, should have known better to use the search bar and look on you tubeI'm not a fan of the rigid stand because you can't get to the bottom bolts. If your not looking to be able to flip or turn the car around the best bang for your buck will be the keyboard stand. If you want similar but not same as the axis stand then the diy speaker stand works.
I am sure the rigid stand can be modified. Ill probably be the first dumbass to try and failThanks for the video, should have known better to use the search bar and look on you tube
I too have one on order, seems like the easy and fairly priced way to start.it'll take me some time to get everything i need but think I'm gonna go with the rigid stand an make my own plate for the rampage and fit a too/parts tray under it.
I'm assuming the top is plastic so if it is ill make diagram of my chassis and cut it upto fit. And figure a way to hold the truckI too have one on order, seems like the easy and fairly priced way to start.
