Splitpin2005
- Norwich
Truck is almost 100% alloy now. As heavy as it is it seems that the shocks struggle now. If i push the truck down it struggles to settle back up to normal height unless i lift the wheels from the ground. Should i just replace the shock oil with standard oil. If so what weight is it. SHould i replace oil with thicker different weight oil???? Or should i do something else. JUst fitting spacers under springs seems a little wrong as only stiffens spring.
Ideas please
Ideas please
