cougar2465
- Sydney
I have a full allum diff housing and covers and there's lots of grease in the house but some how I managed to stripped the bevel diff gears .... any idea?
Cheers
Cheers
No the car was not going hard when this happened, infact it was still warming up on the car park.
There is no shim between the 4 gears and the housing - I also checked in the manual and it doesn't show any shims in the housing... should I put one behind each gears?
By the way, in regards to the second gear pin that keeps falling out, I drilled the whole a bit larger and screw a headless screw (larger diameter than the original pin) in it and it seems to be very very strong now as it has threads where the pin was just pushed in ... still needs to be tested though.
