Suspension Arms
If you don't have the manual download one if you can. Take pictures as you take it apart and put the screws back into the parts as they come off . Then Reverse the process as you put it back together . If the screws are going into metal use a small amount of blue loctite. If a screw is screwed into metal do not force it if it doesn't want to come apart, use a soldering iron or a torch to heat the screw to soften up the old loctite. Big thing is don't rush.
