- Nj
yeh my CV's etc are all in excellent condition, one thing i do is keep well on top of maintenance with my RC's! ..if anything i have OCD when it comes to maintaining them! lol@tizdaz you may want to check your cv shafts as they may need to be taken apart and cleaned/lubed. A friend of mine has a dbxle 2.0 and one of his front shafts had a bit of rust not allowing the cv to move freely.
I looked up on what diff fluid to use & read that 500k centre & then 100k front/rear was a good combo!The center diff fluid has no influence on your drive line friction unless one axle is trying to spin significantly faster than the other. Like the front tires turning into pizza cutters from wildly spinning. Its to eliminate that type of situation. Having 100,000 up front is far to heavy unless straight line drag racing is your thing. My 5ive B rails around turns with 1000 up front, loncked center and 500,000 in the rear. I'm not a racer anymore but like to pretend I'm one when ripping around the property. Lol. If I were serious again, it wouldn't be set up like it is now.
