The MixMizer oil measuring tool
roadrashracing
Green Bay, wi
I was looking around walmart tonight and I found this tool.
http://www.hopkinsmfg.com/10111.html
It basicly a big needle and has different mixtures for 2 stroke oil. It has for liter ,1/2 liter , 1 qt, or one pint of fuel. So I guess you find what you want to mix pull it back to what mix you want and add to fuel, it also has a tube to reach to the bottom of the oil jug. it has measure ments for 16:1 - 100:1. I will try it out in a few weeks.:)
And its made in the usa!
good find, but i tried it. the round fingure hole on the top of the plunger popped off and its hard to get the oil out of the quart container. it comes with a small tube fore the end, but it creates too much pressure. i just use the wifes old measuring cup. she don't cook any way.. 2oz per half gallon.. done..
Been using it for the past 5 years. It's the best one I find since you can do as little and as much as you want. Just check the sides to see if it says 1 litre and 1/2 litre. Mine has 1/2 litre printed on both marked rows.
i tried one too. nice idea, bad manufactureing. mine was a female dog to deal with. went with a ratio right cup.
