Thought it would be faster, but it looks like the age old problem of not enough space.
Exactly more space means les inertia once yo to speed and more speed. I reckon given enough space big triple figure could be seen but it would be of eye sight before you blink.It's driven off the thrust . It would be a lot faster if it were driven off the turbine with a trans.
Of course you could but the clutch system might be prohibitive. When you start thinking about the engagement speeds and forces. One thing in a full size boat or chopper where gearboxes weigh the same or near enough as the engine, another thing in a 1/5th scale.If you really wanted I'm sure you could run off the turbine shaft . They build RC boats with turbines and prop driven .
