if you get another Throttle servo get a hitec 7955T titanium gears, and way more torque specs, which is needed for brake part of that servo. alot of fellow baja'ers use this servo. some use another, but really only bout 2 different ones have i ever heard mentioned, and one being the 7955T which is what i have on mine, and for steering, in case you want to know that, i have the 5755 hitec on mine, read a few different ones used ofr that application, and remember on a hitec, if it goes out, you can send it in, with a application form and after you register them with hitec, and they fix or repair it. the first 5755 i had on mine burnt up while still in setting it up, and i did the stuff, sent it in, and they replaced it for free.
i took his advise not too long ago and could not be happier with the hitec servos he mentioned..really woke up my t1000..HUGE difference!!!:w00t:if you get another Throttle servo get a hitec 7955T titanium gears, and way more torque specs, which is needed for brake part of that servo. alot of fellow baja'ers use this servo. some use another, but really only bout 2 different ones have i ever heard mentioned, and one being the 7955T which is what i have on mine, and for steering, in case you want to know that, i have the 5755 hitec on mine, read a few different ones used ofr that application, and remember on a hitec, if it goes out, you can send it in, with a application form and after you register them with hitec, and they fix or repair it. the first 5755 i had on mine burnt up while still in setting it up, and i did the stuff, sent it in, and they replaced it for free.
