DemonRC1
I just wanted to throw this out for anybody that might be stripping screws consistantly or has lost a set screw... If you are stripping out your set screws on any of the transmission shafts you can use stainless steel set screws from Ace Hardware. You can replace them for around $5. Grind a flat spot on the tips and they will hold much better.
