GTS 666
Because of the way the crank case is designed the motor is not a drop in swap. The case has an extra bolt at the bottom that sit on the rear centre drive shaft. I think I have 2 options 1 remove this bolt and dremel a notch out of the case to clear the shaft or 2 stick the motor I my Hpi baja. I bought this for the redcat not baja so any help or previous experience would be great thanks.
