trooper, the g320 engine doesn't fit in an fg mate,Got a victory pipe coming in hopefully it will fit with the body. If you follow my AreaRC reedcase thread, thats the engine thats going into this RC once I am happy with it.
Well I found this temperature resistant 3d resin. If it doesn't fit. Ill make it fit.trooper, the g320 engine doesn't fit in an fg mate,
the case catches around the drive gear area,
plus the reedcase, because the engines in the fg exhaust forward i'm not sure if the reed cage will clear the rear diff,
yeh they just too big on the case trooper, but, there will be a way somehow to make it fit i'm sureYep spents I see what you mean now. This might not work but I'm still gonna try. Also whoever owned this thing before me.....
It doesn't fit.... This case has an oddball bend where the intake and the case meets.yeh they just too big on the case trooper, but, there will be a way somehow to make it fit i'm sure,
i do know someone from your side of the pond had an rcmk twin fitted to there fg stadium/monster,
there are some vids on spewtube somewhere , i think he raised the engine up ofr sommat to get it to fit,
oh, and when ya take the drive gear off the brake shaft, warm the grub screws up and use a decent allen key cos the grubs strip out easy and then need drilling out etc,
that looks a tad manky, looks like fuel leak or seal or gasket leak on that old engine,
i would say go for an obr upto 30.5 trooper ,
not sure on the case fitment with the scz either, obr would be safe bet for fitment,
just looked at the scz and again i'd say there may be issues with the reed cage/case clearing the rear diff,
thats sommat you'd need to check on,
scz's rev very high though, dean at bonehead-rc ran one in a baja a few years ago and managed to squeeze over 21k rpm out of one,
good point. I was thinking about a billet case lately because some people swear by it. Even if it adds a small bit of bottom end id be happy. Im thinking about the TR one or the Gizmo one. Im not 100% on the gizmo because IDK if its the smaller bore size or the G320 yet and the G320 does not fit in the FG Monster...Yes you can use a CY case.
23 - 31.5 (4bolt) cases are the same, just different heads to get bore and stroke.
Be sure to use the zenoah upper rod hardware if you use in a CY case. Check which part specifically, I'm not fully up yet.?
Isn't turtle racing part you mentioned, just a clutch case?.
Lightened flywheels opinions are varied. They rev faster but some say you lose a little bottom end from the weight removal the choice is yours. It might make a difference in a lighter vehicle but I think its subjective.
