Ive had my CY engine now for about 1.5 yrs now. Im having difficulty tuning it. Its low end acceleration if fine (does wheelies occasional), its when it goes from the high needle back to the low needle it just decides to cut out. So I try and change where the needle is, yet still the same thing happens time and time again (cuts out)
It has a wt 668 carb and a ddm dom pipe.
Can anyone suggest the low and high needle combination to make it run consistently. (if you have the same engine, carb and pipe
Also ive noticed that its incredibly easy to turn over and was wondering if its time to change the piston ring??
Any help/advice would be greatly appreciated
